Astro A50 Battery Replacement
    1. Astro A50 Battery  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro A50 Battery  Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro A50 Battery  Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To begin, remove the foam cushions from each earpiece by gently pulling the cushion away from the housing.
      • Use a small Phillips-head screwdriver to remove the 4 screws.
    2. Astro A50 Battery  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro A50 Battery  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro A50 Battery  Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Take extra care when removing objects that are glued down as they are subject to tear.
      • After setting aside the black plastic covers, use the screwdriver again to remove the two screws.
      • Identify the foam inner covers and peel back the upper corners of each foam to expose and remove the screws beneath.
    3. Astro A50 Battery  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro A50 Battery  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently fold aside the speaker assembly to expose the internals of the earpiece. Use caution to avoid damaging the black wires.
      • Remove the four screws marked in red to release the faceplate on the outside of the headset.
    4. Astro A50 Battery  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro A50 Battery  Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the earpiece over, and expose the battery by folding the microphone and cover plate away from the battery housing.
      • Desolder battery connections to disconnect the three colored wires from the old battery. Make note of corresponding colors/locations for installation of new battery.
      • Carefully remove the old battery by wedging a plastic opening tool or spudger underneath the battery to release the adhesive.
      • Do not bend or puncture the battery housing.
      • For reassembly, follow steps 1-4 in reverse order:
      • Take care to ensure battery wires are soldered correctly with each color on its corresponding pad.
      • Use minimal amounts of adhesive to re-attach the speaker foam to avoid glue making a mess.
Be sure to test your new battery to make sure the fix succeeded.
crwdns2935229:040crwdne2935229:0
Nicholas Eriksen
crwdns2935283:010/28/15crwdne2935283:0
987 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-5, Shastany Fall 2015 crwdns2935289:0UMass Dartmouth, Team 2-5, Shastany Fall 2015crwdne2935289:0
UMASSD-SHASTANY-F15S2G5
crwdns2935297:048crwdne2935297:0
crwdns2947412:033crwdne2947412:0
Could you post the dimensions of the battery itself? Seems like it's hard to find one that may or may not fit. That or could you recommend where to get a battery?
lolubad umad - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i'd also like to know where to source the battery
drbob44 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Search for part no: 603443 on Ebay - ~$10 or buy one from Astro for $75
mattgorringe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
So, which battery is the best replacement for the original? Is it possible to put some bigger batteries inside with some modding?
Rene Siekmann - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Battery sizes are mAH, just by a 900 or more and that should do the trick. The actual size of the battery must be identical for a perfect fit and confortable headsets. Just make sure you get the correct voltage and size.
The battery comes with a cable, instead of soldering, can I tie those cables in? Also, what is the best way to remove and reattach foam cushions without damaging them?
cpaalvarez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 71
crwdns2936753:030crwdne2936753:0 311
crwdns2942667:0crwdne2942667:0 101,167
