Astro A50 2016 Headset Buttons Replacement
Vincent Seguin
crwdns2944107:0crwdnd2944107:0Vincent Seguincrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 23, 2022crwdne2944111:0
crwdns2931287:06crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Buttons can get sticky or become unresponsive. This guide will show you how to remove them for cleaning or replacing them.
crwdns2944105:0crwdne2944105:0
  1. Astro A50 2016 Headset Buttons Replacement, Headset Speakers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro A50 2016 Headset Buttons Replacement, Headset Speakers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Buttons Replacement, Headset Buttons: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6mm PH1 screws.
  6. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6 mm PH1 screws.
  7. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Dettach the thin circuit board from the ribbon with your hand by pulling the board and wire in different directions.
    Hola, buenas noches me podrías decir cómo se llama esa placa delgada. Necesito esa refacción, porfavor
    omar ramirez marin - crwdns2934203:0crwdne2934203:0
  8. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the two unscrewed buttons away from the ear cuffs with your hand.
  9. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6mm PH1 screws.
    • Pull the unscrewed button away from the ear cuffs with your hand.
    This button on step 9 has become unresponsive. Any ideas?
    john Streff - crwdns2934203:0crwdne2934203:0
  10. Astro A50 2016 Headset Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro A50 2016 Headset Buttons Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands to pull the volume wheel up and away from the device.
    What if the dolby surround sound button does not toggle on or off
Vincent Seguin
crwdns2935283:010/02/17crwdne2935283:0
382 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G1, Livingston Fall 2017 crwdns2935289:0Cal Poly, Team S15-G1, Livingston Fall 2017crwdne2935289:0
CPSU-LIVINGSTON-F17S15G1
crwdns2935297:013crwdne2935297:0
hola una pregunta saben donde consiguen la rueda de volumen ya que mis astro a50 de tercera generacion de xbox tiene un problema cuando le giras la rueda para subir el volumen y bajar el volumen ya que no funciona del todo bien, en pocas palabras no hace bien su funcion al regular el sonido al girar la rueda y quisiera reparar eso.
bryan200131 - crwdns2934203:0crwdne2934203:0
Yo también tengo el mismo problema. He encontrado unas piezas similares en Ali express pero no sé si le queden a los astro a50. Son de la marca Logitech pero para los G933. La pieza se ve muy parecida. Para evitar problemas yo estoy buscando la placa de circuitos completa, pero no la he encontrado. Si sabes algo te agradecería lo compartieras
crwdns2942667:0crwdne2942667:0 2,505
