Astro A50 2016  Headset Battery Replacement
Andrew Monson
crwdns2944107:0crwdnd2944107:0Andrew Monsoncrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 14, 2025crwdne2944111:0
5 - 10 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
The battery is what gives the headset the power to run and function. This guide will show you how to remove the battery from the headset.
crwdns2944105:0crwdne2944105:0
  1. Astro A50 2016  Headset Battery Replacement, Headset Speakers: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro A50 2016  Headset Battery Replacement, Headset Speakers: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the magnetic ear pads by gently pulling up away from the head set.
  2. Astro A50 2016  Headset Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016  Headset Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016  Headset Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the speaker module up off the device.
  5. Astro A50 2016  Headset Battery Replacement, Headset Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro A50 2016  Headset Battery Replacement, Headset Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 6mm PH1 screws.
    • Remove the buttons panel by pulling the panel away from the white ribbon cord.
    I don't think these are PH1 screws.
    Felix - crwdns2934203:0crwdne2934203:0
  6. Astro A50 2016  Headset Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro A50 2016  Headset Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 6mm PH1 screws.
    • Remove the tape holding the wires connected to the motherboard.
  7. Astro A50 2016  Headset Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back panel by squeezing the two tabs together and pushing out.
  8. Astro A50 2016  Headset Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  9. Astro A50 2016  Headset Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery by using the plastic opening tool to pry it away from the headset.
    How to take off the cover cap, where he takes the battery out?
    Wie entfernt man die Kappe, wo er die Batterie rausnimmt?
    Tim Uninteressant - crwdns2934203:0crwdne2934203:0
    Thats step 7 the picture is a little confusing but once you see it you will understand.
    Joe Steenblock -
    Question? Is there 1 package of batteries or 2 sets of packaged batteries for both sides or just the 1 side only?
    Dar rin - crwdns2934203:0crwdne2934203:0
    Thank you, Your explanations helped me to change the USB connector.
    Roger, Rimouski, Québec, Canada
    roger - crwdns2934203:0crwdne2934203:0
    I think there is a missing step (8.5?). im trying to check how I can remove the plate cover where the battery is. is this just a snap on? (too scared to try)
    Bryan P - crwdns2934203:0crwdne2934203:0
    Thanks for the guide! I've just fixed mine by following it. Btw, there's no need to remove any internal screws, with a small tweezer you can move the battery cables freely, and solder the new ones.
    Mike M - crwdns2934203:0crwdne2934203:0
crwdns2935229:014crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Andrew Monson
crwdns2935283:010/02/17crwdne2935283:0
505 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S15-G1, Livingston Fall 2017 crwdns2935289:0Cal Poly, Team S15-G1, Livingston Fall 2017crwdne2935289:0
CPSU-LIVINGSTON-F17S15G1
crwdns2935297:013crwdne2935297:0
crwdns2947412:014crwdne2947412:0
Is this for the Gen III Astro a50?
vic.bianco - crwdns2934203:0crwdne2934203:0
Yes it’s for the Gen 3 A50
Crisdavid -
Where do I buy a battery though….
Brandon Phillips - crwdns2934203:0crwdne2934203:0
how can I connect the new battery ?
Ahmed f - crwdns2934203:0crwdne2934203:0
you connect the new battery by soldering it to the same spot you de-soldered the old battery from
Ryan Green - crwdns2934203:0crwdne2934203:0
I can see why you have to unscrew the mainboard but I screwed it back after taking the game/voice control cover off as it was hard to desolder/solder back on the battery with it moving around. To anyone new to desoldering/soldering; make sure you have room and something to rest your hands while doing either (my hands shaked cause I had nothing to rest), make sure your soldering iron is hot enough to heat the solder but not too hot (obviously), use some non sharp pliers to hold the wires when you solder the new battery and to help pull the wires away when you desolder the old battery. This was my first time doing either and it took some time to get the wires soldered to the board but just take your time getting comfortable. I normally wouldn’t be comfortable doing something like this but I wasn’t going to drop another ~$250 for a new headset and if it went bad I could just put it back together and just plug in a micro usb cable to keep it powered till I found someone with some experience to solder the battery.
Crisdavid - crwdns2934203:0crwdne2934203:0
1 battery on the right ear side.
Rakan -
on my headset, the step 5 middle screw in the bottom is a ph 00
bbs282 - crwdns2934203:0crwdne2934203:0
If you're new to soldering, look up "how to tin wires soldering" on a search engine and do that before you try to solder the wires on.
Also put some flux on the 3 contacts and on your new battery wire ends. It will make a really clean connection when you solder them, minimizing the possibility of crossing battery wires. Don't add any extra solder, what's left on there after removing the old wires, is enough when you tin the new battery wires.
Hope that helps someone! I just did mine and I have a working headset again!!
wood.micah - crwdns2934203:0crwdne2934203:0
Can I just cut the wires from the old battery and then splice them together with the new battery wires?
Frog Pizza -
تم تغيير البطارية بنجاح اخذتها من علي اكسبريس ب18$ شامل الشحن والضريبة
فكيت السماعه ورحت لمحل صيانة الكترونيات وسوى لي التلحيم
البطارية يبدو انها سليمه وتعمل كما هو متوقع لكن احتاج اعمل لها عدة دورات شحن للتأكد
وراح احدّث ردّي بعد تجربتها لفترة ان شاء الله
رابط البطارية: اختر موديل 2016 تبع الجيل الثالث بالصوره 900 مللي امبير لكن اللي وصل 800 مللي امبير مثل الأصلية
https://www.aliexpress.com/item/10050065...
Thank you, iFixit.
Rakan - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 43
crwdns2936753:030crwdne2936753:0 179
crwdns2942667:0crwdne2942667:0 28,937
