If the Astro A20 will not turn on or the battery will not charge then you will need to replace the battery.
Place one hand on the hard side of the headset ear portion and on the cushion.
Lift the small portion on the edge of the cushion.
Slide the metal spudger underneath the lift part of the ear cushion.
Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
All of this is accurate, except the battery & motherboard Are on the charging port side, opposite mic side unlike picture. The right earphone is correct side.
Remove the ear cushion from the headset.
Place hand on the opposite side of the speaker.
Remove the four 7mm screws with a Phillips #1 screwdriver.
Lift and remove the speaker from the headset.
Remove the two 7mm screws with a Phillips #1 screwdriver.
Lift the motherboard to expose the battery.
Remove the battery with a plastic spudger.
Where did you manage to find a replacement battery?
Where do I get the battery from can not find it on eBay only can find for the Astro a50 I need it for the Astro a20
Hey, does anyone know where I can find that battery?
Does it work for Astro A20 2nd Gen too?
this guide is so wrong! 1st the battery is on the left side by the charging port (a20 2gen)
