If the Astro A20 does not have any audio transmitting from the speaker then you will need to follow these steps to replace the speaker.
Place one hand on the hard side of the headset ear portion and on the cushion.
Lift the small portion on the edge of the cushion.
Slide the metal spudger underneath the lift part of the ear cushion.
Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
Remove the ear cushion from the headset.
Place your hand on the opposite side of the speaker.
Remove the four 7mm screws with a Phillips #1 screwdriver.
Lift the speaker area.
Disconnect the wires connected to the speaker.
Wedge a spudger on the edge of the speaker and lift upwards to remove the speaker from the device.
