The Astro A20 microphone replacement guide shows the steps of replacing a microphone with the use of a 60 mm extension, Phillips #1 screwdriver, and a new microphone.
Place one hand on the hard side of the headset ear portion and on the cushion.
Lift the small portion on the edge of the cushion.
Slide the metal spudger underneath the lift part of the ear cushion.
Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
All of this is accurate, except the battery & motherboard Are on the charging port side, opposite mic side unlike picture. The right earphone is correct side.
Remove the ear cushion from the headset.
Place one hand on the back of the speaker.
Remove the four 7mm screws with a Phillips #1 screwdriver.
Lift the speaker area.
Disconnect the wires that connect the microphone.
Remove the 7mm screw with a Phillips #1 screwdriver.
crwdns2935229:08crwdne2935229:0
crwdns2944067:04crwdne2944067:0
worked for me….thanks
listen my mic peace is messed up is there like a fix for that
were? are you getting the new mic from? please link the site
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
