In order to replace the motherboard, you are going to have to access it first. After that, you will have to separate everything from the old motherboard and reconnect everything to the new motherboard.
Remove the four bottom tabs in order to access the bottom screws.
Remove all four 14 mm Phillips #1 screws.
Pry up the motherboard on the four points using a spudger.
Gently pull back the motherboard to expose many of the component's wired connections.
Sever the indicated adhesive connections to the motherboard allowing the wired connections to be removed.
The red wires may be adhered to the CPU as indicated and will need to be severed as shown.
Sever the additional adhesive connections so that the wired connections may be removed.
Locate and unscrew the indicated screw using the (PH1) Phillips head bit.
Screw Measurements: (Length= 5.3mm)
Remove the last two wired connections to the motherboard by severing the indicated connections.
Lift up the secondary motherboard as indicated using the metal spudger.
All connections should be severed from the motherboard and a new motherboard may be inserted.
