Astak Mole Antenna Replacement
  1. Astak Mole Antenna Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the SD card.
  4. Astak Mole Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Antenna Replacement, Antenna: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astak Mole Antenna Replacement, Antenna: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the antenna in a counter-clockwise rotation.
  7. Astak Mole Antenna Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the screw holding the antenna wire with the PH1 size Phillips head bit.
    • Screw length: 5.3mm
  8. Astak Mole Antenna Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry open the circuit board attached to the antenna wire using a metal spudger.
  9. Astak Mole Antenna Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the antenna female end from the motherboard.
Meshari Alkhelaiwi
crwdns2935283:009/15/16crwdne2935283:0
143 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S2G2
crwdns2942667:0crwdne2942667:0 599
