Astak Mole Motor Replacement
crwdns2869540:0crwdne2869540:0: 1K
2
33
105
1,046
crwdns2955950:0crwdne2955950:0: 2
crwdns2960004:02crwdne2960004:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Replacing the motor requires access to the motherboard and it is suggested to place screws into magnetic tray to avoid loss of important screws. Removal of the rotational motor assembly is simple but it may be difficult to find a replacement motor online.
    1. Astak Mole  Motor Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four bottom tabs in order to access the bottom screws.
    2. Astak Mole  Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove all four 14 mm Phillips #1 screws.
    3. Astak Mole  Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the SD card.
    4. Astak Mole  Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    5. Astak Mole  Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull back the motherboard to expose many of the component's wired connections.
    1. Astak Mole  Motor Replacement, Electric Motor Assembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
      • Screw Measurements: Length: 7.1mm
      • The motor should be free of its housing and only be attached to the motherboard by its wires.
    2. Astak Mole  Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Sever motor connection to motherboard and remove wire carefully.
      • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
Andrew Birch
crwdns2935283:009/15/16crwdne2935283:0
204 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-2, Blackwell Fall 2016 crwdns2935289:0USF Tampa, Team 2-2, Blackwell Fall 2016crwdne2935289:0
USFT-BLACKWELL-F16S2G2
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 105
crwdns2959996:0crwdne2959996:0 1,046
