Assembling Reflective Parabolic Dish
  1. Assembling Reflective Parabolic Dish, Assembling Reflective Parabolic Dish: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Assembling Reflective Parabolic Dish, Assembling Reflective Parabolic Dish: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, be sure you have all parts and tools needed for assembly and a construction area that is at least two meters in diameter.
    • Lay two triangular sections side-by-side with pointed edges and bases adjacent to each other.
    • Since the sections are not flat, it is advisable to prop one end up on a box or similar object to give more stability during assembly.
  2. Assembling Reflective Parabolic Dish: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the 10 mm nuts and bolts to attach the two plates together. First, hand thread each bolt/nut pair, then use two 10 mm wrenches secure them.
    • DO NOT install a nut and bolt in the THIRD hole from the center (pointed end of the section). This is where the Pipe Ring Bracket is attached later on.
  3. Assembling Reflective Parabolic Dish: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Assembling Reflective Parabolic Dish: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Assembling Reflective Parabolic Dish: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After firmly fastening the two sections together, return to the third hole which was left empty. In addition to a nut and bolt, you will also need a pipe ring bracket.
    • Install the 10mm nut/bolt again but with the bolt passing through the single holed side of the bracket. Hand thread and use 10mm wrenches to tighten.
    • Be sure the bracket is NOT installed between the edges of the dish sections.
    • The direction the bracket faces does not matter.
  4. Assembling Reflective Parabolic Dish: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Assembling Reflective Parabolic Dish: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Repeat steps 2-3 until you have assembled the entire reflective dish, complete with all six sections.
    • Remember to install the pipe ring brackets in the correct place all the way around the reflective dish in the third hole from the center.
To disassemble your device, follow these instructions in reverse order.
Griffin Paul
crwdns2935283:010/18/13crwdne2935283:0
391 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-30, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 4-30, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S4G30
crwdns2942667:0crwdne2942667:0 1,852
