Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar
  1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  3. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
To disassemble your device, follow these instructions in reverse order.
Ashlie Reott
crwdns2935283:010/20/13crwdne2935283:0
340 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-30, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 4-30, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S4G30
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 661
