With frequent use and the heavy weight of clutter, cabinet drawer slides can easily deform, causing the drawer to not slide smoothly. We present a guide that will explain how to replace a drawer slide of a cabinet drawer.
Pull the drawer out.
Use a screwdriver and remove the screw connecting the drawer slide bracket to the drawer.
Repeat the previous bullet for both sides.
Pull off the drawer slide bracket from the internal railing.
Remove the screws on the internal railing that needs to be replaced by twisting the screwdriver counterclockwise.
Hold up the new internal railing against the cabinet wall and screw it in using the same screws and by twisting the screwdriver clockwise.
The drawer slide should be facing towards the ceiling and then place the ball bearing runner directly into it, so it fits snugly.
Align the new drawer slide with the ball bearing runner onto the internal railing and snap them into place.
Check that the drawer slide glides in and out properly.
Screw the drawer slide back onto the drawer by turning the screwdriver clockwise.
Do this for both sides.
Then, you can push the drawer smoothly back in.
