Arnova 7K G3 Camera Replacement
  1. Arnova 7K G3 Camera Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement, Rear Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Arnova 7K G3 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Arnova 7K G3 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
  7. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two Phillips #00 screws from the motherboard.
  8. Arnova 7K G3 Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
  9. Arnova 7K G3 Camera Replacement, Camera: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arnova 7K G3 Camera Replacement, Camera: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the camera and camera ribbon connection on the backside of the motherboard.
  10. Arnova 7K G3 Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unlock the camera ribbon connector clip using a pair of tweezers.
  11. Arnova 7K G3 Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arnova 7K G3 Camera Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently by hand, remove the camera and its ribbon by pulling the camera away from the motherboard.
    • There is adhesive foam on the backside of the camera that may cause some difficulty when removing the camera.
Kue
crwdns2935283:003/18/15crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
Michigan Tech, Team 1-2, Lauer Spring 2015 crwdns2935289:0Michigan Tech, Team 1-2, Lauer Spring 2015crwdne2935289:0
MTU-LAUER-S15S1G2
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 321
