Unplug the vacuum before repair. The cord is easily disconnected and replaced once the vacuum is disassembled adequately.
Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
Remove the 15 mm T20 screw. This screw is located nearest the power cord.
Gently separate the upper and lower sections of the main housing.
Pull the black wire from the power cord out of the switch.
Remove the five 15mm screws from the plastic motor cover and power cord clamp using a PH2 screwdriver.
Detach the white wire from the motor by pulling upwards on the wire as you depress the small metal tab on the connector with a nylon spudger.
