ArmorAll AA255 Motor Replacement
  1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ArmorAll AA255 Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ArmorAll AA255 Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ArmorAll AA255 Motor Replacement, Motor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
  6. ArmorAll AA255 Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ArmorAll AA255 Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ArmorAll AA255 Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
  7. ArmorAll AA255 Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ArmorAll AA255 Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ArmorAll AA255 Motor Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
  8. ArmorAll AA255 Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ArmorAll AA255 Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
  9. ArmorAll AA255 Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ArmorAll AA255 Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motor is ready for replacement. Pull the motor to separate.
YeaJun Yoo
crwdns2935283:002/11/16crwdne2935283:0
302 crwdns2915208:0crwdne2915208:0
IUPUI, Team 2-1, Baechle Spring 2016 crwdns2935289:0IUPUI, Team 2-1, Baechle Spring 2016crwdne2935289:0
IUPUI-BAECHLE-S16S2G1
What is the motor product no? It will help if there is a link to buy the motor
Austin K - crwdns2934203:0crwdne2934203:0
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - crwdns2934203:0crwdne2934203:0
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - crwdns2934203:0crwdne2934203:0
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 73
crwdns2942667:0crwdne2942667:0 5,009
