Arlo Pro 2 Base Station Sensors Replacement
  1. Arlo Pro 2 Base Station Sensors Replacement, Base Station Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement, Base Station Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement, Base Station Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws on the side of the base station, above the USB ports.
    • Pull apart the top case from the bottom.
    • This may require some force as there are internal catches.
  2. Arlo Pro 2 Base Station Sensors Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a TR10 Torx screwdriver to remove the two 10 mm screws to disconnect the motherboard from the base casing.
    • The motherboard is connected to the USB ports; when removing it be careful to gently remove the USB ports from their cavities to avoid any damage.
  3. Arlo Pro 2 Base Station Sensors Replacement, Base Station Sensors: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement, Base Station Sensors: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement, Base Station Sensors: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Follow the black wire running from each thin metal sensor to the motherboard; they will be connected under a piece of black tape.
    • Pull back the black tape to see where the wire you are following attaches to the motherboard.
    • Pull up on the coaxial connector to disconnect the wire from the motherboard.
  4. Arlo Pro 2 Base Station Sensors Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Arlo Pro 2 Base Station Sensors Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Snake the wires through any place where it goes through the plastic casing.
    • Gently pull the metal sensor away from the plastic casing to fully disconnect it from the motherboard.
Ben I.
crwdns2935283:003/26/25crwdne2935283:0
493 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-2, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 2-2, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S2G2
crwdns2942667:0crwdne2942667:0 36
