Using this guide will help you replace the batteries in your Archos 101 G9 tablet.
Most mobile devices (including tablets) use built-in batteries to keep their electronic devices running. Make sure the device is turned off and not plugged in to any external power source prior to beginning this guide. Be careful when opening up the device; the display is attached to the rest of the tablet with a ribbon cable. Don’t bend the batteries excessively while completing the last step. Bending the batteries can possibly lead to overheating and may cause a fire. Never use metal prying tools to remove a battery.
Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
When you reach the corner, carefully pry the two halves of the device apart.
Repeat for the remaining three sides and corners.
Gently remove both ribbon cables from their sockets on the motherboard.
Remove the white and black coaxial cables with gold tips from the motherboard.
Remove the display assembly from the back panel.
Remove the tape covering the solder connections on the motherboard.
Desolder the BATT+ connection from the motherboard.
Desolder the BATT- connection from the motherboard.
Desolder the NTC+ connection from the motherboard.
Desolder the NTC- connection from the motherboard.
Remove the black tape from the top of each battery.
Remove the yellow tape from the batteries.
Gently pry the batteries away from the case using a nylon spudger.
