Aranet 4 Display Replacement
  1. Aranet 4 Display Replacement, Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aranet 4 Display Replacement, Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery door and the batteries.
    • Unscrew the two T6 screws.
    • Turn your device over so that the screen faces you and remove the cover.
  2. Aranet 4 Display Replacement, Removing the old screen: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aranet 4 Display Replacement, Removing the old screen: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aranet 4 Display Replacement, Removing the old screen: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back the screen.
    • Carefully release the display ribbon cable by, depending on your board revision either lifting the brown cover on the flip-up connector or sliding out the stuffer actuator connector. (Refer to the images for clarification.)
    • Remove the old screen.
  3. Aranet 4 Display Replacement, Placing new screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the new screen's cable into the connector (black side up).
    • Carefully place the front cover back and reassemble the device.
It is not necessary to remove the the board from the bottom-case, if you do wish to do this be carefull not to break the battery terminals!
spoofer
crwdns2935283:006/11/24crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
Great info and instruction. But….. amazone does not ship to The Netherlands.
Cees Doets - crwdns2934203:0crwdne2934203:0
Hi Cees,
You can look for products sold on amazon in different countries using the ASIN number.
Here's a link for the Netherlands: https://www.amazon.nl/dp/B071HW4Z6N
Good luck with your repair!
spoofer -
Yes yes yes. Both my Aranet’s work again.
Thanks for the guide! I successfully repaired my Aranet4 by following it. A couple of notes:
- I was able to get a better price than Amazon for the replacement display at https://www.waveshare.com/product/displa....
- The connector for the flexible printed circuit board on my model didn't flip up, but instead slides forward. I found documentation for the connector (or something very very similar to it) here: https://www.te.com/content/dam/te-com/do... (search for "Stuffer Actuator (Plunger Style)")
Jon Manning - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 331
