Use this guide to replace the 20-inch sediment pre-filter for your Aquasana F-300R 300,000-gallon whole house water filtration system.
The sediment pre-filter keeps rust, dirt, and sediment particles from entering the main filter unit.
After 2-3 months of use (when the pre-filter darkens or water flow slows), the sediment pre-filter must be replaced. When this pre-filter is not replaced in a timely manner, water pressure can drop, and sediment particles can enter and clog the main filter tank.
Turn off the water supply by turning the water valve(s) to be horizontal, or perpendicular to the water pipe.
Press the black pressure release button on top of the filter housing.
Hold the button down for 5 seconds.
Unscrew the filter housing canister clockwise with a water filter housing wrench.
Remove the dirty pre-filter and dispose of it.
Wash the filter housing canister with dish soap and water.
Rinse and dry the filter housing canister.
Remove the O-ring from the housing canister.
Clean off old grease on the O-ring with a towel.
Replace the O-ring.
Apply Vaseline or lube around the seal.
Place the new pre-filter in the center of the filter housing canister.
Screw the filter housing canister counter-clockwise with your hands.
Tighten the filter housing canister with the filter wrench.
Turn on the water supply by turning the water valve(s) to be vertical, or parallel to the water pipe.
Run water in a sink or tub for 1-2 minutes to flush out the system and remove any air in the pipes.
Repeat steps every 2-3 months for best results.
