Use this guide to replace a cracked or broken filter box with a regular plastic box. This guide will provide you with the instructions and tools to repair your aquarium top filter. The added benefit you can achieve from this guide is that you can customize the filtration system best suited for your aquarium. The tools listed in this guide are easily accessible and can be found online or in any hardware store.
Using a black sharpie marker, mark the box for accurate holes.
Use the utility knife to cut a hole in the marked position to attach the pipe.
Using the same utility knife, make a hole in the bottom of the plastic box for the water to come out.
Attach the soft PVC pipe with the aquarium powerhead.
Insert the soft PVC pipe in the plastic box.
With a telfon tape properly wrap the soft PVC pipe for no leakage of water.
Use aquarium-safe silicone glue to seal the soft PVC pipe with the plastic box.
Add your desired filter media best suited for your aquarium.
Finally, submerge the waterpump in water and adjust the waterflow.
