Aquaris M5 Mainboard Replacement
  1. Aquaris M5 Mainboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aquaris M5 Mainboard Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Aquaris M5 Mainboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Aquaris M5 Mainboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
  4. Aquaris M5 Mainboard Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
    • Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
    • Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
  5. Aquaris M5 Mainboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
    • Twist the spudger to lift up the mainboard shield.
    • Remove the mainboard shield from the phone.
  6. Aquaris M5 Mainboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to disconnect the battery's flex cable from the mainboard.
    • Pull of the sticker on the bottom side of the battery.
    • Grab the sticker and lift it up to take the battery out of the phone.
  7. Aquaris M5 Mainboard Replacement, Front Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement, Front Camera: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement, Front Camera: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • FPC Connectors can break easily, be very careful.
    • Use an opening tool or your finger nail to open the FPC connector.
    • Disconnect the FPC connector cable.
    • Use the tip of a spudger to leverage the camera out of its housing.
    • Remove the front camera.
  8. Aquaris M5 Mainboard Replacement, Rear Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aquaris M5 Mainboard Replacement, Rear Camera: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat side of a spudger to disconnect the camera's flex cable.
    • Use Tweezers to grab the camera and lift it out of the phone.
  9. Aquaris M5 Mainboard Replacement, Mainboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement, Mainboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement, Mainboard: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a SIM card eject tool, to eject the two SIM card slots on one side.
    • Use a SIM card eject tool, to eject the micro SD card slot on the other side.
  10. Aquaris M5 Mainboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to unplug the antenna cable in the bottom right of the mainboard.
    • Use a spudger to disconnect the two flex cables at the bottom of the mainboard.
  11. Aquaris M5 Mainboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the flex cable at the top of your the mainboard.
    • Bend the cable a bit over the edge, so it won't block the mainboard later, when you are taking it out.
  12. Aquaris M5 Mainboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the 4mm Phillips #00 screw, holding the mainboard to the frame.
  13. Aquaris M5 Mainboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Aquaris M5 Mainboard Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger between the mainboard and the mid frame.
    • The best spot is on the right side next to the two SIM card slots.
    • Use the spudger to lever the mainboard.
    • Take the mainboard out of the phone.
Theo Mat
crwdns2935283:011/12/17crwdne2935283:0
12.949 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 870
