Apple iPod Hi-Fi iPod Dock Inserts Replacement
  1. Apple iPod Hi-Fi iPod Dock Inserts Replacement, Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
  4. Apple iPod Hi-Fi iPod Dock Inserts Replacement, Front Panel and Speaker Connections: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Hi-Fi iPod Dock Inserts Replacement, Front Panel and Speaker Connections: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
    • Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
  5. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry out the large speaker with a metal spudger around the edge.
    • Remove the speaker slowly from its socket with your hands.
    • Turning the speaker on its side will make this step much easier.
    • The speaker is still attached by several connections at this point so the speaker will not be able to be removed completely at this step.
  6. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press down on the tab and pull out with your hands to remove the cable connecting the large speaker from the rest of the unit.
    • Pull the large speaker completely out and set aside.
  7. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the sensor connection by pulling it straight out with your hand.
  8. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the entire front assembly off by prying it up with the spudger and lifting the assembly off with your hands towards the top of the Hi-Fi.
    • There are still connections attached at this stage so the front assembly will not completely disconnect from the rest of the device .
  9. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clips for the remaining two speakers by repeating step 6.
    • Remove the last connection that connects the speakers to the power box.
    • Remove the front panel completely.
    • When reassembling, the ports are labeled "right" and "left" to help you plug in the right speaker to the right port.
  10. Apple iPod Hi-Fi iPod Dock Inserts Replacement, iPod Dock Inserts: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the speaker on its back with the dock facing away from you.
  11. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable connected to the dock insert by pulling the cable straight out.
  12. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the gold tape attaching the insert to the unit.
    • Remove the three 2mm Phillips #1 screws holding the dock inserts in by placing the screwdriver in the head of the screw and rotating counterclockwise.
  13. Apple iPod Hi-Fi iPod Dock Inserts Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the dock insert with your hands.
crwdns2935229:05crwdne2935229:0
Timothy Scheuermann
crwdns2935283:004/18/18crwdne2935283:0
710 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S16-G1, Livingston Spring 2018 crwdns2935289:0Cal Poly, Team S16-G1, Livingston Spring 2018crwdne2935289:0
CPSU-LIVINGSTON-S18S16G1
If I need broken part of Apple iPod Hi-Fi iPod Dock were to get and how to get it part
wyzman nyawo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 5,710
