crwdns2943259:0crwdnd2943259:0crwdnd2943259:0crwdnd2943259:0crwdne2943259:0
During this guide you will need some solder skills to repair the product. If you don't have any experiences in soldering, take a look at the How to Solder and Desolder Connections guide. Make sure you have all the tools that's needed to desolder en solder. Be aware of the fumes—do this in a well ventilated room!
Unscrew the four Phillips screws on the backside of the docking system.
Separate the housing in two parts.
The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
Slide the dock connector out of the housing part.
Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
Remove the T-shaped circuit board holder.
Remove the circuit board from the housing part.
Disconnect the 5-pin connector between the two circuit boards.
Look how the cables are oriented.
Take a picture with your phone. It's easier to look it up than recalling your memory.
Trigger the desoldering pump before heating the solder.
If the solder becomes fluid, keep the desoldering pump near the solder.
Push the button on the desoldering pump to suck the solder.
Strip the cables with a wire stripper.
Check if the cable is in the right position.
Heat up the contact point on the circuitboard.
If the contact point is hot enough, you can add a little bit of solder.
To reassemble your device, follow these instruction in reverse order from step 7
crwdns2934873:0crwdne2934873:0
94%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
