Apple iPod Dock Connector Cable Replacement
  1. Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the four Phillips screws on the backside of the docking system.
    • The screws are located quite deep. Make sure you have a long screwdriver to be able to reach the screws.
    • Be aware of the plastic threads. Using too much force can tear this up.
  2. Apple iPod Dock Connector Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the housing in two parts.
    • The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
    • The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
    • The internal parts are still connected to each other. Don't pull the housing parts too far from each other.
  3. Apple iPod Dock Connector Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the dock connector out of the housing part.
  4. Apple iPod Dock Connector Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
  5. Apple iPod Dock Connector Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the T-shaped circuit board holder.
  6. Apple iPod Dock Connector Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the circuit board from the housing part.
    • The circuit board is still connected to another circuit board with a cable.
  7. Apple iPod Dock Connector Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the 5-pin connector between the two circuit boards.
    • The connectors are tightly connected. Hold the other circuit board to prevent it from breaking while disconnecting the 5-pin connector.
  8. Apple iPod Dock Connector Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Dock Connector Cable Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Look how the cables are oriented.
    • Take a picture with your phone. It's easier to look it up than recalling your memory.
  9. Apple iPod Dock Connector Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Desoldering Pump
    $3.99
    crwdns2942207:0crwdne2942207:0
  10. Apple iPod Dock Connector Cable Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat up the solder.
    • If you don't want to damage your workspace, it's probably handy to place something underneath.
    • The circuit board will be getting hot. To make it more stable you can clamp it in a vise or alligator clips.
    • The heated solder tends to fume—do not inhale this! Do this in a well ventilated room.
  11. Apple iPod Dock Connector Cable Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Dock Connector Cable Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If the solder becomes fluid, keep the desoldering pump near the solder.
    • Push the button on the desoldering pump to suck the solder.
    • Solder will solidify fast, so you need to act quickly.
  12. Apple iPod Dock Connector Cable Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Strip the cables with a wire stripper.
  13. Apple iPod Dock Connector Cable Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple iPod Dock Connector Cable Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check if the cable is in the right position.
    • Heat up the contact point on the circuitboard.
    • If the contact point is hot enough, you can add a little bit of solder.
    • Don't inhale the fumes.
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
Anoniem
crwdns2935283:003/08/17crwdne2935283:0
19 crwdns2915208:0crwdne2915208:0
Delft University of Technology, Team S1-G6, Flipsen Spring 2017 crwdns2935289:0Delft University of Technology, Team S1-G6, Flipsen Spring 2017crwdne2935289:0
TUD-FLIPSEN-S17S1G6
crwdns2942667:0crwdne2942667:0 479
