Apple XServe Raid Battery Replacement
  1. Apple XServe Raid Battery Replacement, Raid Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple XServe Raid Battery Replacement, Raid Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the drive module(s) from the front of the Xserve.
    • Depending on configuration, there may be up to three modules.
  2. Apple XServe Raid Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power supplies from the system by pulling on the built-in removal bar.
    • Depending on configuration, there may only be one power supply unit.
  3. Apple XServe Raid Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
    • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
  4. Apple XServe Raid Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple XServe Raid Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple XServe Raid Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
  5. Apple XServe Raid Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the raid battery connector using a plastic spudger.
  6. Apple XServe Raid Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple XServe Raid Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SAS backplane power cable by pulling the cable out of the board.
    • Remove the data cable from the board using a spudger to lift the connector out of the socket.
    • Loosen the Phillips #0 screw holding the backplane in the system.
    • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
  7. Apple XServe Raid Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the single Phillips #0 screw on the power backplane.
    • Slide the backplane out of the connector on the main board, and lift it straight out.
  8. Apple XServe Raid Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the raid card battery out of the chassis.
Cody West
crwdns2935283:010/20/20crwdne2935283:0
234 crwdns2915208:0crwdne2915208:0
Texas Tech, Team S14-G2, Cowan Fall 2020 crwdns2935289:0Texas Tech, Team S14-G2, Cowan Fall 2020crwdne2935289:0
TTU-COWAN-F20S14G2
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 918
