You need a Metal spudger and a screwdriver
Insert a metal spudger to open the plastic part under the Keyboard
Pull the lock up and disconnect the connection cable
Keeping the connection cable, push out the logic board's placement
Remove the logic board from the placement
crwdns2935229:020crwdne2935229:0
crwdns2947412:09crwdne2947412:0
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
