crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Apple Watch SEcrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Apple Watch SE Mother Board Removal, Removing the Taptic Engine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the Taptic Engine: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew Tri-screw and remove small plate cover.
    • Then, remove these two Tri-screws.
  2. Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the Taptic Engine pt. 2: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Undo both connectors highlighted.
    • Then the Taptic engine should be able to be lifted out.
    • The Taptic engine has some adhesive on the cable outlined in blue that sticks it to the speaker.
  3. Apple Watch SE Mother Board Removal, Removing the Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the Speaker: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect this connector.
    • Then remove these 3 tri-screws.
  4. Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the Speaker pt. 2: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the speaker slowly.
    • Where my tweezers are located seems to be the best place to remove the speaker.
  5. Apple Watch SE Mother Board Removal, Removing Brackets around the MB: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing Brackets around the MB: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 4 more Tri-screws are removed here.
    • Gently pulling back the screen flex cables reveals 2 more Tri-screws that should be removed.
    • Then the brackets can be removed with tweezers.
  6. Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing Brackets around the Power Button: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove these 2 Tri-screws.
    • After taking off the first bracket, take of the next Tri-screw and remove the second bracket.
  7. Apple Watch SE Mother Board Removal, Disconnecting Power button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Watch SE Mother Board Removal, Disconnecting Power button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Power button FPC.
    • The FPC here has 2 connections. DO NOT pry in the middle as it may bend.
  8. Apple Watch SE Mother Board Removal, Removing the MB.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the MB.: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Watch SE Mother Board Removal, Removing the MB.: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting in the bottom right corner as show here. Gently wedge in a spudger and pry up on the board.
    • Once you are able to get a good hold on the board move try pulling down and to the right in a clockwork motion.
    • Do this motion slowly as there is a final connector under the board.
  9. Apple Watch SE Mother Board Removal, Completion: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the board is lifted out, the final connector is highlighted.
    • Disconnect and you are all done!
    • Repeat steps backwards to put everything back together.
jessepugsley
crwdns2935283:001/21/20crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 174
crwdns2942667:0crwdne2942667:0 7,398
