Apple TimeCapsule A1355 opening for repair
  1. Apple TimeCapsule A1355 opening for repair, cutting the rubber: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple TimeCapsule A1355 opening for repair, cutting the rubber: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple TimeCapsule A1355 opening for repair, cutting the rubber: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • all measures are with the rubber still on. and it stays on.
    • first you take a cutter and cut little squared or circles or what you prefer into the rubber. and then, f.e with the screwdriver tear of the rubber on the incicion you just did.
    • there are exact measures in millimetres. I recommend to turn the TimeCapsule with connections facing you and then start from the lower left corner.
    • fyi: 1 inch = 25,4 mm, 1 feet = 304,8 mm
    • Note: the green lines indicate that the screws are in alignment with each other.
    • Note: the different color circles indicate screws. I found only the 1. gen TimeCapsule sometimes be having the purple screws. with the 2.,3.,4. Generation I never found the purple ones.
  2. Apple TimeCapsule A1355 opening for repair, different generations: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • the first generation is sometimes different. I had ones where in the purple markers are screws . sometimes they are reveted from the other side, and must not be removed.
    • the 2,3,4 generation have almost the same screws. sometimes the brown ones dont exist.
  3. Apple TimeCapsule A1355 opening for repair, opening the box: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • turn the TimeCapsile 90D clockwise.
    • then get something where you can lean on the opened but still connected part. (in my case I used another time capsule for it)
    • then carefully open the lid to the left. and carefully put it aside like shown on the picture
    • after that you can do inside whatever you desire. in my case I took out the hard drive
  4. Apple TimeCapsule A1355 opening for repair: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • if you are nerdy or have too much time on your hand, you can keep the cut-out rubber pieces and after replacement you can glue the right parts back in.
    • note: nobody sees the bottom of the TimeCapsule in general.
    • so I did not.
    • ENJOY
Martin David
crwdns2935283:005/27/13crwdne2935283:0
314 crwdns2915208:0crwdne2915208:0
Thank you for detailed explanation of the screws positions.
I successfully replaced my faulty hard drive to the new one.
Artur Pędziwilk - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 101
crwdns2942667:0crwdne2942667:0 6,806
