Apple Time Capsule Model A1254 Back Plate Replacement
  1. Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Time Capsule Model A1254 Back Plate Replacement, Back Plate: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
  2. Apple Time Capsule Model A1254 Back Plate Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Time Capsule Model A1254 Back Plate Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
  3. Apple Time Capsule Model A1254 Back Plate Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Time Capsule Model A1254 Back Plate Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
crwdns2935229:09crwdne2935229:0
Keaton Frahmann
crwdns2935283:010/06/16crwdne2935283:0
825 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 4-2, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 4-2, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S4G2
crwdns2935297:017crwdne2935297:0
I had to open to destroy the hard drive for security reasons. The rubber bottom was so old it just tore to bits. I used a Dremel Multi-Max with a flat scraper blade to remove it in the end.
steve - crwdns2934203:0crwdne2934203:0
must I put back on the rubber bottom or can I leave it off for maximum airflow?
Strider - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 141
crwdns2942667:0crwdne2942667:0 6,813
