This guide will show you how to remove the power supply/heatsink of the Apple TV so it may be replaced.
Remove the 4mm T7 Torx screw.
Remove the 5mm T7 Torx screw and its accompanying washer.
Use the plastic opening tool to tip the board upward.
Remove the four (4) 4mm T7 Torx screws anchoring the power supply to the case.
Remove the two (2) 4mm T6 Torx screws holding the power supply plug.
Pull the power port away from the side of the casing.
Dislodge the rubber power indicator light cowling's adhesive with a fingernail.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Extract the rubber power indicator light cowling with tweezers by first pulling the cowling directly away from the case wall, until it clears the clear plastic nub of the diffuser, and then upwards.
Insert two of your 7mm T7 Torx screws into the indicated posts on the power supply/heatsink.
Using screw removal pliers, pull up on the screws, alternating between them, until the unit is free from the case.
crwdns2935229:08crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Where could one find such a power supply for the 4th generation Apple TV. Sadly this one went out without even a years worth of light use.
Lewis,
If its under a year just have apple replace it. I just replaced the powersupply with one I aquired on ebay. It didn’t power on when I was done with the fix. I didn’t go all inspector gadget on it, but with the plethora of heatsinks on this thing I bet some circuitry fried due to a heat issue.
Found a replacement power supply on eBay- started working great. Hope it stays that way.
This instructions were perfect. Found power supply, replaced in about 15mins. Apple TV powers up again. Saved me from buying another.
THANK YOU
New Power Supply Board PA-1110-7A1 for Apple TV 4th Generation A1625by WFLNHBLearn more: https://www.amazon.com/dp/B07R4LBZ16/ref...
What value fuse is used in Apple tv 4th gen power supply ?
