As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
Disconnect the power supply connector from the logic board with a spudger.
Below the power supply connector is another small 2 pin connector which must be removed as well (I just do not know how), else the board cannot be lifted. On the second picture it is already removed, so here is clearly a step missing here.
crwdns2935229:010crwdne2935229:0
Where can I find a 3rd Generation Apple TV Logic Board?
Good question! Did you manage to find a replacement?
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mine too, where could I find a logic board replacement???
where so i find a new base to replace it with
sharpeEZz - crwdns2934203:0crwdne2934203:0
