Apple TV 1st Generation Fan Replacement
crwdns2869540:0crwdne2869540:0: 13K
3
21
105
12,849
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 5
crwdns2959982:05crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
Replace the fan in your Apple TV 1st Generation.
    1. Apple TV 1st Generation Fan Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the Apple TV over so that the bottom of the unit is facing up.
      • You need to remove the rubber base to get access to the screws.
      • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
      • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
      • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
      • The rubber base can tear if the adhesive hasn't been softened enough.
      • Repeat the procedure described above until the rubber base has been completely removed.
    2. Apple TV 1st Generation Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the four T10 Torx screws that secure the lower case to the upper case.
    3. Apple TV 1st Generation Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
      • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
    4. Apple TV 1st Generation Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple TV 1st Generation Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully pull the hard drive data cable straight up from its socket on the logic board.
      • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
    1. Apple TV 1st Generation Fan Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The fan is held in place by three rubber posts.
      • Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
      • During reinstallation, it helps to lubricate the rubber posts. Try weaving a string through the holes in the posts to pull them up through the mounting points.
      • Do not excessively pull on the posts, as they may rip.
    2. Apple TV 1st Generation Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
      • Lift and remove the fan out of the upper case.
ropel
crwdns2935283:011/11/09crwdne2935283:0
119 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 18-5, Maness Fall 2009 crwdns2935289:0Cal Poly, Team 18-5, Maness Fall 2009crwdne2935289:0
CPSU-MANESS-F09S18G5
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 105
crwdns2959996:0crwdne2959996:0 12,849
