Apple Studio Display M7649 Inverter Replacement
crwdns2869540:0crwdne2869540:0: 8.2K
5
22
102
8,207
crwdns2959984:0crwdne2959984:0: 5
crwdns2959974:05crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
Replacing the inverter, a common cause for what looks to be a loss of backlight.
    1. Apple Studio Display M7649 Inverter Replacement, Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Studio Display M7649 Inverter Replacement, Stand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lay the display facing down with the stand away from you.
      • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
    1. Apple Studio Display M7649 Inverter Replacement, Panels: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
    2. Apple Studio Display M7649 Inverter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Rotate the display so the legs of the display are now facing you
      • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
    3. Apple Studio Display M7649 Inverter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
    1. Apple Studio Display M7649 Inverter Replacement, Metal EMI Shield: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
    2. Apple Studio Display M7649 Inverter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Now locate and remove the lone Phillips screw holding the EMI shield to the display
    3. Apple Studio Display M7649 Inverter Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Studio Display M7649 Inverter Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Now that the screw has been removed, slide the panel towards your body and lift it out.
      • You may need to remove the clear USB port cover to remove the metal EMI shield.
    1. Apple Studio Display M7649 Inverter Replacement, Inverter: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove these three screws holding the board to the display
    2. Apple Studio Display M7649 Inverter Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove these five cables connection the inverter to the backlights and logic board.
      • Taking note where they connect to for reassembly
    3. Apple Studio Display M7649 Inverter Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove and replace the inverter
crwdns2935229:05crwdne2935229:0
Andrew Tsao
crwdns2935283:001/19/10crwdne2935283:0
186 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-20, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 3-20, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S3G20
crwdns2935297:096crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 102
crwdns2959996:0crwdne2959996:0 8,207
