Apple Studio Display M2454 Main Computer Cable Replacement
  1. Apple Studio Display M2454 Main Computer Cable Replacement, Main Computer Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, the back panel needs to be removed to access the cable connectors.
    • Locate the three 2mm hex screws located on the top of the stand and remove them.
    • Now locate and remove the four 2mm hex screws on the corners of the back panel.
    • Now remove the back panels while pulling the cable through them without damaging either part.
  2. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal back plate by using the #2 philips head screwdriver and removing the top screw.
    • Now remove the two other philips screws located below the cable with the philips head screwdriver.
    • With all the screws removed, push the metal plate towards the bottom of the monitor to release the clips holding it to the monitor.
    • Pull the metal plate away.
  3. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the four #2 phillips screws located on the corners of the stand bracket, using the phillips head screwdriver.
    • Pull bracket away from monitor.
  4. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable hold-down with #2 phillips head screwdriver.
  5. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw at the bottom of the plastic bracket, using #2 phillips head screwdriver.
    • Pull the plastic bracket free.
    • Note the plastic pegs lining the bracket up with the monitor.
  6. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove tape holding down the white connector to the LCD main board.
  7. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With tape removed, the connections on the LCD main board can be disconnected.
    • First, remove the single hold-down using the philips head screwdriver.
    • Now locate the three connections the main cable makes with the monitor. Two are on the LCD Main Board and one other to the side.
    • Disconnect the white connector to the LCD main board by gently lifting tab with small pry tool and pulling out.
    • The tabs can easily break off, be extra careful
    • Disconnect the black connector to the LCD main board by pressing the tab and pulling out.
  8. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now remove the connection not on the LCD Main Board by pulling back the tape holding the wires down first.
    • Remove the connector by hand.
  9. Apple Studio Display M2454 Main Computer Cable Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finally, the main cable can be replaced by pulling the old cable away and repeating the previous steps in reverse with a new, working main cable.
Dylan Perry
crwdns2935283:001/20/10crwdne2935283:0
177 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-27, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-27, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G27
crwdns2942667:0crwdne2942667:0 5,773
