Apple Studio Display M2454 CCFL Inverter Replacement
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Studio Display M2454 CCFL Inverter Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
Dylan Perry
crwdns2935283:001/20/10crwdne2935283:0
177 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-27, Maness Winter 2010 crwdns2935289:0Cal Poly, Team 13-27, Maness Winter 2010crwdne2935289:0
CPSU-MANESS-W10S13G27
crwdns2942667:0crwdne2942667:0 7,042
