Apple Powerbook 5300 Trackpad Replacement
  1. Apple Powerbook 5300 Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Powerbook 5300 Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To begin this repair process first position the Powerbook towards you with the monitor closed, also make sure the laptop is away from anything that can cause a fire, self harm, etc.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out. Make sure you place the battery in a safe place where it can also be easily accesible
    • ALSO NOTE: The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Trackpad Replacement, Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For the next step you are to grab the TR8 Torx Security Screwdriver
    • Once you have the screwdriver turn the laptop over and look for three T8 torx screws that should be located near the bottom panel of the device.
    • Once located, begin unscrewing and place screws in a comfortable space where they are easily accesible
  3. Apple Powerbook 5300 Trackpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws are off carefully turn the laptop over, make sure the monitor of the device is facing you
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use the spudger tool to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Trackpad Replacement, Trackpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Powerbook 5300 Trackpad Replacement, Trackpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To begin the replacement process, refer to the prerequisite guides listed in the details portion of the guide.
    • To begin, carefully grip the bottom portion of the computer as pictured.
    • Next, lift up on the front portion of the laptop.
    • Watch out for the ribbon cable. Damage to this cable may result in harm of computer peformance.
    • Carefully disconnect it by grasping the cable, pulling straight up and out of its connector.
  5. Apple Powerbook 5300 Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Powerbook 5300 Trackpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the mouse button in place, unscrew the two screws using the TR8 Torx Security Screwdriver.
    • Now carefully slide the button out, while doing this make sure you are maintaining hold of the cable as pictured.
  6. Apple Powerbook 5300 Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Powerbook 5300 Trackpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the last torx #8 screw holding the trackpad assembly in place.
    • Now the entire trackpad will lift out of place.
    • Disconnect all ribbon cables from their connectors.
    • Note: refer to the first picture for a reference for reassembly.
Scott
crwdns2935283:004/26/11crwdne2935283:0
155 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-30, Garner Spring 2011 crwdns2935289:0Cal Poly, Team 25-30, Garner Spring 2011crwdne2935289:0
CPSU-GARNER-S11S25G30
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 6,096
