Apple PowerBook 520 Memory (RAM) Replacement
  1. Apple PowerBook 520 Memory (RAM) Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple PowerBook 520 Memory (RAM) Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With monitor hinge at the bottom, remove the two top center screws.
    Not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - crwdns2934203:0crwdne2934203:0
  3. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove top left and top right screws.
    Also not necessary for RAM, hard drive, or CPU replacement.
  4. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove middle left and middle right screws.
  5. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    Again not necessary for RAM, hard drive, or CPU replacement.
  6. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift keyboard from bottom and take out of shell.
  7. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
  8. Apple PowerBook 520 Memory (RAM) Replacement, Memory (RAM): crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the panel on back of the device. Remove 2 T8 torque screws.
  9. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic panel underneath the LCD Screen.
  10. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
  11. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the logic board protection plate.
  12. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
    Beware: there might be a little plastic 'bridge' piece that goes around the memory connector (mine had one that isn't in this guide) which needs to be removed first before removing the RAM card. It was both difficult to remove and fragile (broke on one side during removal).
  13. Apple PowerBook 520 Memory (RAM) Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the old Memory board is removed, replace it with the new Memory board.
Tyler
crwdns2935283:004/10/11crwdne2935283:0
148 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 20-66, Walters Spring 2011 crwdns2935289:0Cal Poly, Team 20-66, Walters Spring 2011crwdne2935289:0
CPSU-WALTERS-S11S20G66
crwdns2942667:0crwdne2942667:0 3,607
