Apple Magic Keyboard Keys Repair
      • Remove the batteries.
      • Remove the plastic cover on the bottom. (On older models, this cover is not centered.)
      • Remove the small screw.
      • Use a flat blunt tool to loosen the ribbon cable clamp. To do this, pull the front part away from the rear part.
      • Pull out the ribbon cable.
      • Put the batteries back in (without screwing the cover on).
      • Push in the batteries to release the circuit board assembly.
      • Carefully pull out the circuit board assembly. Pay attention to the ribbon cable.
      • Soak the keyboard in alcohol (methylated spirits). It should be completely covered. Use an airtight container.
      • Keep moving the container to get the liquid everywhere.
      • Wait 24 hours
      • Take the keyboard out of the liquid and shake it out well.
      • CAUTION!! This step is not absolutely necessary!! Opening the keyboard further is only necessary if you want to gain access to the circuit paths.
      • The plastic cover on the back can now be easily detached. To do this, use a flat blunt tool to go into the gap and pry off the plastic cover. The alcohol has softened the glue.
      • Let the keyboard dry well. To speed up the process, you can put it into the sun.
      • Put the parts back together in reverse order. When installing the circuit board unit, make sure that you pull the ribbon cable to the side.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Sebastian Reindl
crwdns2935283:005/02/20crwdne2935283:0
268 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 194
crwdns2942667:0crwdne2942667:0 6,443
