Use this guide to help you optimize audio function from your Apple EarPods.
X-ACTO Knife
Tweezer
Triangle Paddle
Alcohol
Cotton Swabs
Using a triangle paddle, apply sufficient pressure to get in-between the opening section
Soak one side of a cotton swab with alcohol
Clean inner and outer pod using swab soaked in alcohol
Carefully clean the speaker cone using cotton swab
Once clean, reattach the earbud
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Carefully remove grill out of both earbuds using tweezers
Take precautions not to bend grill excessively
Clean grill with cotton swab soaked in alcohol
Remove any build up of wax or sweat
Once the grill is clean, place the grill back inside of the apple earbuds
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
crwdns2935229:08crwdne2935229:0
When I re assemble they won’t stay closed. Do I glue them back together?
