Apple Cinema Display M8149 USB Port Replacement
  1. Apple Cinema Display M8149 USB Port Replacement, USB Port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Cinema Display M8149 USB Port Replacement, USB Port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Cinema Display M8149 USB Port Replacement, USB Port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
  2. Apple Cinema Display M8149 USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Apple Cinema Display M8149 USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Apple Cinema Display M8149 USB Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Once the screws are removed, lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. Apple Cinema Display M8149 USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the USB cable routing screw (8 x 2.72mm) using the PH 2 screwdriver.
  4. Apple Cinema Display M8149 USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the USB cable connector from the screen box.
  5. Apple Cinema Display M8149 USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple Cinema Display M8149 USB Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the PH 2 screwdriver, unscrew the two screws (4.85 x 2.94mm) on the USB ports.
Kyle Suguitan
crwdns2935283:004/01/11crwdne2935283:0
21 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-41, Forte Spring 2011 crwdns2935289:0Cal Poly, Team 10-41, Forte Spring 2011crwdne2935289:0
CPSU-FORTE-S11S10G41
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,489
