Apple AirPort Extreme Model A1034 USB Port Replacement
  1. Apple AirPort Extreme Model A1034 USB Port Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 USB Port Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple AirPort Extreme Model A1034 USB Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
  9. Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple AirPort Extreme Model A1034 USB Port Replacement, USB Port: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
Michael Garcia
crwdns2935283:010/12/11crwdne2935283:0
411 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-15, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-15, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G15
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 3,221
