Apple AirPort Extreme Model A1034 Internet Card Replacement
  1. Apple AirPort Extreme Model A1034 Internet Card Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Internet Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Internet Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple AirPort Extreme Model A1034 Internet Card Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Internet Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Internet Card Replacement, Internet Card: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 1mm phillips screws from the bottom.
  6. Apple AirPort Extreme Model A1034 Internet Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the top and bottom of the metal casing. You will now expose the motherboard and AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
Michael Garcia
crwdns2935283:010/12/11crwdne2935283:0
411 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-15, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-15, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G15
crwdns2935297:013crwdne2935297:0
Thank you so much for your guide! I was challenging myself to do it without cheating, but couldn't figure out how to release the bottom plastic layer from the main unit inside after I undid the 3 Torx screws. Thankfully you avoided me having to break the whole unit by showing where the central screw hidden beneath the S/N 3 barcode sticker was and that it was Philips not Torx, and I can now pinch the A1027 wifi card and use it in my G5, instead of relying on ageing ethernet! Bless you kind folks!
HumptyDumpty - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,351
