Apple AirPort Extreme Model A1034 Antenna Replacement
  1. Apple AirPort Extreme Model A1034 Antenna Replacement, Outer Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Apple AirPort Extreme Model A1034 Antenna Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Antenna Replacement, Antenna: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4mm phillips screws to remove antenna.
  6. Apple AirPort Extreme Model A1034 Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The circuit board connected to the antenna is attached to the metal case with foam adhesive.
    • Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
Michael Garcia
crwdns2935283:010/12/11crwdne2935283:0
411 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-15, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-15, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G15
crwdns2935297:013crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 4,815
