Instructions on how to replace a damaged touchscreen display.
Begin by inserting the plastic opening tool into the seam between the back and front of the case and carefully pry the back from the front.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Moving along the seam continue to pry the case apart.
The back panel should now be disconnected from the device. This provides access to the components of the device for repairing and replacing parts of the tablet.
Remove the three screws that are located at the top of the circuit board with the screwdriver. (2.4 mm head, 3.9 mm in length)
Remove the touchscreen.
Replace the touchscreen.
