Aorus X5 v6 Display and Connector Replacement
    • For this you need a T6 torx screwdriver. The panel pops off easily with a little pull at a corner.
    • The panel has clips at the rear, so pop off the front side first.
    • It is always a good idea to disconnect the battery before doing any repairs.
    • You actually do not need to open the bottom panel to replace the display. This is done as a precaution, but if you are replacing the connector, you would need to open it anyway.
  1. Aorus X5 v6 Display and Connector Replacement, Carefully peel off the aluminium display frame.: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The frame is very thin and glued onto the laptop.
    • Wobble a thin flat tool (preferably out of plastic) in between the frame and display to remove the glue. I used a metal scraper, but I do not recommend this because it easily scratches aluminium.
    • Start from the sides, go to the upper corners and go around slowly removing glue. Be very careful around the webcam, and bottom because this is where the electronics are exposed.
Adam Pitas
crwdns2935283:011/30/18crwdne2935283:0
216 crwdns2915208:0crwdne2915208:0
Hi. Is there anywhere I can try finding the custom Aorus 40pin LCD LVDS cable? I have an Aorus X5 V6 (3k screen). I tried replacing the monitor and that didn't work. I can tell it's a backlight issue and I am suspecting the connector is faulty. Sourcing this cable is difficult. Hoping you can point me in the right direction? I tried Gigabyte support but I have no idea if anyone will ever respond there.
Help! :)
Eccentric Husky - crwdns2934203:0crwdne2934203:0
Hi there - Have you managed to find a replacement cable?
neverwhere20 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 1,221
