Anne Pro 2 Case/Housing Replacement
  1. Anne Pro 2 Case/Housing Replacement, Case/Housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anne Pro 2 Case/Housing Replacement, Case/Housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anne Pro 2 Case/Housing Replacement, Case/Housing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the Anne Pro 2 Keyboard.
    • Turn off the Anne Pro 2 Keyboard using the switch on the bottom.
  2. Anne Pro 2 Case/Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anne Pro 2 Case/Housing Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a keycap remover, remove the the following keycaps: Left Alt, Space Bar, Right Shift, Backslash, Y, H, and the Tab key.
  3. Anne Pro 2 Case/Housing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anne Pro 2 Case/Housing Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Torx T5 bit, remove the five screws from the keyboard.
  4. Anne Pro 2 Case/Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anne Pro 2 Case/Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard slowly from the bottom side.
    • Do not fully lift the PCB because the battery is still plugged in.
  5. Anne Pro 2 Case/Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anne Pro 2 Case/Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently unplug the battery connector by wiggling it back and forth.
  6. Anne Pro 2 Case/Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anne Pro 2 Case/Housing Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the PCB from the main case.
    • Gently lower the PCB into the Zero-Degree housing from the top side first.
    • Firmly press it in once you have lowered it.
  7. Anne Pro 2 Case/Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anne Pro 2 Case/Housing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Screw the five T5 Torx screws back into place.
  8. Anne Pro 2 Case/Housing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anne Pro 2 Case/Housing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the seven keycaps you removed and gently place them in their intended spots on the keyboard.
    • Firmly press them in, ensuring they are flush with the rest of the keys.
Mohamed
crwdns2935283:009/15/20crwdne2935283:0
205 crwdns2915208:0crwdne2915208:0
York University, Team S2-G3, Melo-Thaiss Fall 2020 crwdns2935289:0York University, Team S2-G3, Melo-Thaiss Fall 2020crwdne2935289:0
YORK-MELO-THAISS-F20S2G3
Anne Pro 2 Software manage the illumination, open the mobile App and choose a pre-programmed scheme or design your own pattern, with a distinct colour for each key if desired. The programmes are easy to use and work on both Mac and PC.
Visit Here-   https://www.techtoreview.com/top-picks/a...
Abhinav Pal - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 11,111
