crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Anko 2 Sandwich Jaffle Makercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Anko 2 Sandwich Jaffle Maker Teardown, Anko 2 Sandwich Jaffle Maker Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay product flat on a clear and clean surface.
  2. Anko 2 Sandwich Jaffle Maker Teardown, PPE and removal of power cable.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • As this is a teardown, we want to minimise the risk of any injuries. Firstly, ensure all PPE is warn including gloves and face shield. Next, cut the power cable to prevent in-proper reassemble.
  3. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Base Internal Handle Plate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of Base Internal Handle Plate: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open up the product.
    • Use a Philips-Head Screwdriver to remove these 4 screws.
    • The plate can then be removed.
  4. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Base Heating Plate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 highlighted screws at the top of the heating plate.
  5. Anko 2 Sandwich Jaffle Maker Teardown, Disconnecting wires of Base Heating Plate.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the Base Heating Plate from casing to reveal internal wires.
    • Remove the 3 highlighted screws.
  6. Anko 2 Sandwich Jaffle Maker Teardown, Cutting Wires: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use wire cutters to snip the connecting wires to the heating element.
  7. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Wire Covering: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of Wire Covering: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip product over so the bottom is facing upwards.
    • Remove the 2 highlighted screws.
    • Slide out the black cover. Keeping in mind there is a tab on the left hand side.
  8. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Wiring.: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the wire casing, gently pull on the wires and feed them through the hole. It should come out as a whole unit.
  9. Anko 2 Sandwich Jaffle Maker Teardown, Silicone Feet: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Simply pinch and squeeze each silicone foot to remove from the outer shell.
  10. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Top Internal Handle Plate: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of Top Internal Handle Plate: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open up the product and lay flat on the top side
    • Repeating Step#3, use a Philips Head screwdriver to remove the 4 screws that are highlighted.
  11. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Top Heating Plate: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 highlighted screws on the Top Heating plate.
  12. Anko 2 Sandwich Jaffle Maker Teardown, Disconnecting Wires of Top Heating Plate: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the Top Heating Plate, leaving the outer case laying on the bench.
  13. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Thermostat: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of Thermostat: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once screws have been removed, gently wiggle and dislodge the thermostat.
    • NOTE: There will be a layer of thermal paste between the thermostat and heating plate. Grab an old rag to wipe off.
  14. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Heat Shield: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the thermostat has been removed, gently grab the heat shield cover and remove.
  15. Anko 2 Sandwich Jaffle Maker Teardown, Removal of LED's: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of LED's: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of LED's: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch and slide up the 2 highlighted silicone stoppers.
    • Once stoppers have been removed, apply slight force the remove the LED's from respected colours.
  16. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Coloured Diffusers: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of Coloured Diffusers: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the extrusions of the coloured diffuser and apply slight downward force to remove via the outer side of the product.
    • NOTE: Arrows indicate where to pinch.
  17. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Clip: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of Clip: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anko 2 Sandwich Jaffle Maker Teardown, Removal of Clip: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This is a snap fit piece. Apply slight pressure to one side of the clip and work one side first to pop off from the casing.
    • The outer casing can now be fully separated from the heating plates.
  18. Anko 2 Sandwich Jaffle Maker Teardown, Removal of Wiring Top Heating Plate: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Either use pliers to remove the solder between the wires and the heating element.
    • Or
    • Use wire cutters to snip the wires as completed in Step#6.
  19. Anko 2 Sandwich Jaffle Maker Teardown, Separation of Heating Plates.: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Simply apply an angle to both heating elements and release from the hinge connection.
  20. Anko 2 Sandwich Jaffle Maker Teardown, Exploded View: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lay Parts Flat For Exploded View
zed
crwdns2935283:003/16/24crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 94
