Anki Vector Infrared Sensor Replacement
  1. Anki Vector Infrared Sensor Replacement, Belts: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Raise Vector's arms above his head.
  2. Anki Vector Infrared Sensor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector Infrared Sensor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your thumb and index finger, grab the lower portion of the belt near the large wheel and pull the belt off.
    • Repeat on the other side.
  3. Anki Vector Infrared Sensor Replacement, Infrared Sensor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector Infrared Sensor Replacement, Infrared Sensor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull each front wheel cover off.
    • This will require a good amount of force due to the three clips holding it in place.
  4. Anki Vector Infrared Sensor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector Infrared Sensor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the wheel with the Phillips #00 screwdriver and gently remove it.
  5. Anki Vector Infrared Sensor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two body screws beneath the wheel using the same screwdriver.
  6. Anki Vector Infrared Sensor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anki Vector Infrared Sensor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull off the front panel to unplug the Infrared sensor.
    • Be careful when pulling off the front panel. The Sensor is connected by wires to both the panel and the device.
Shay Takei
crwdns2935283:004/16/19crwdne2935283:0
1,759 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G6, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G6, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G6
crwdns2942667:0crwdne2942667:0 872
