Is your Anker Soundcore Space Q45 plastic covering damaged, preventing you from using the device to its full capability? If so, here is a guide to fix the problem.
Use the iFixit opening tool to disconnect three clips holding the outer covering in place.
Clips at 3 o'clock, 7 o'clock and 11 o'clock
Image shows right headphone, battery is in left.
Remove three screws holding the inner plastic covering in place with a Phillips screwdriver.
