Are your Anker Soundcore Space Q45 ear cushions old or damaged, preventing you from using the device to its full capability? If so, here is a guide to fix the problem. All you will need is an iFixit Opening Tool to separate the cushions from the plastic clips.
Insert an iFixit opening tool in between the cushion and the plastic.
Detach six clips holding the cushions in place.
Lift the cushions away from the headphones.
How can I replace the headband foam ?
